Hydraulic Clutch Pedal Adjustment: how?
I have the bentley, but it doesn't quite explain it very well. I just installed the 034 firewall brace and I just need to adjust my pedal a little bit. I'd like to know what exactly to do. If any of you guys have pics that' would be great.
Thanks!
Thanks!
At the end near the pedal there is a piece that spins, this is how you adjust the pedal length. There should be a plug of some sorts and a circlip that holds the pedal to the master. Undo that and you can spin the end of the master. Its like a U shaped thing with holes at the end. I had to adjust mine as well after I installed the brace (which sucked!).
The studs that hold the master cylinder to the firewall were in my master cylinder. I did not even attempt to get it out either. So I did not use the studs that Javad sent along with the kit. Just wondering if you had studs or bolts in your master cylinder? Thanks
Tony Hoffman-4000Q
13
03-18-2008 09:53 AM
Ragdoll
10-11-2007 08:37 AM
eph94
06-12-2006 03:37 PM
ButchHusky
11-16-2005 10:25 AM
