I got all the way to injector reinstallation before the plastic broke...
I should've used lube when shoving them back in there. I was holding out hope for the original plastic inserts not to give way since I had no luck finding replacements previously.
Oh well, can somebody lemme know if these are the right injector-shroud-inserts for the KX motor?
Fuel Injector Inserts 063133555 NOS Set of 5 – Quattroholics
They look correct but I've ordered the wrong shrouds once before.
Hello,
if you have an KX with hydro lifters then these are wrong. You should have the 2 piece version (Brass/Plastic) The once in you r link are for the very early engines around 1980 or so.
Ciao
Werner
Ciao
Werner
Ah thanks, ended up finding the lower plastic pieces from several vendors online. For anybody in the future who needs these, PN is 035 133 554, which will yield some results when searched through google or ebay.
Corey
05-13-2002 08:43 AM
