I have a bad leak in the cabin
I have just recently noticed this leak, and last night it a downpour I took the time to check it out, and I can't seem to tell where it's coming from. The floor on the pass side is completely soaked. I cannot see any water on the roof. I looked underneath the car and I cannot see any holes. If it is raining and I get into the car the water is there, so im guessing it's not coming from underneath. There is no water up under the dash, and the rear seats seem to be dry as do the door panels. Is there any problematic places that these cars leak from that would cause this? When I got in last night and took off it made a sucking noise from the pass side, sounded like it was coming from the "gutters." Thanks guys!!!
I get a leaky floor in the rear passenger side, and some wetness on the front passenger side. See my post below with lots of suggestions and even an "updated leak post" within the post itself...
Hope it helps?
--morgan<ul><li><a href="https://forums.audiworld.com/4000/msgs/69845.phtml">Click!</a></li></ul>
Hope it helps?
inside. Is looked as if water was getting between the inner and outer door skins via the poor seal between the felt and the window. it would then migrate in through the bottom of the door.
I have no screws holding it in, just latched. Im gonna pull it and the computer to get the screws in right tomarrow along with looking at the places you guys mentioned for the leaks. I also have to seal one of my tails. After the steelers game it's the find that "leakage game" thanks guys.
Jeff Doble
09-21-2004 04:09 PM
DavidFeygin
02-12-2002 12:51 PM
