I need to replace the temp sensor...
that goes to the ECU.
Does this look like the right part?
Thermo-Time Switch; Brown with 2 Pin Connector; 15 Degree C, 8 second
Part # 0280 130 219
<img src="https://www.autohausaz.com/secure/PartImages/0280130219.jpg">
Part # 0280 130 219
From the description, (not the part number), that sounds like the trigger for the cold start injector (It's either on, or off. TImes out after a few seconds or cranking, depending on engine temp).
You want the sensor that's a variable resitor, depending on temperature...
egp320i
09-28-2005 10:08 PM
beyerdbx
09-16-2005 06:43 PM
CDNA4LOVR
10-02-2000 03:07 PM
