Ignition problems (part 2)
Earlier I posted that my car was lacking power when the timing was set to specs and would only run right at full advance. Well it turns out that when I set the timing, the idle microswitch was not being thrown. Now I fixed it and the ECU "knows" the car is at idle. So when I went to set the timing again I was shocked when I could only get 1 degree retarded when the distributer was turned to the max. I double checked my measurements and used a timing light with dial-in advance. So I am confused, a few people told me that the timing belt slipped on the intermediate shaft, but you would think that is would be noticable if it slipped. Any ideas?? All I know is that somthings not right...
The timing is set to spec or it isn't. If the valve timing is off in relation to the ignition timing then you are screwed (if it is getting up in miles then you are far better off changing the belt seals and water pump NOW). The microswitch makes no difference on the I-5. On a 4-cyl, the timing can be dragged back by the knock sensor.
In the I-5 at least you can quick check this by setting the flywheel mark at tdc and the dist mark at tdc and look to see if the cams are pointing in the right direction.
About to do timing belt, is a pully puller needed or can I crack the cam pullys with a screw driver?
picnicbob
30v V6 Discussion
01-19-2006 04:34 PM
metalv8
07-16-2004 06:57 AM
Åudios69
12-02-2002 06:57 AM
