Ignition timing help! 2.3 NG
my coupe has the 2.3l NG and i have no idea how to set the ignition timing. I know its set improperly and I cant find timing marks anywhere. Ive read that you just set the distributor to #1 TDC and leave it up to the ecu to control the timing. Is that completely true? and what does the ecu use to measure the timing other than the knock senor? which is new
Okay, sounds like two different issues. First you need to find the timing marks, per above. More specifically, the driver side of the bell housing is where you look to see the mark on the fly wheel. If possible, rotate the engine by hand (clockwise), until you see the mark and put a dot of paint on it. Otherwise it'll be nearly impossible to see when the engine is running.
Next, while you have that mark showing in the window at TDC (there should be a step or mark on the window that you line up with the flywheel mark), verify that the dot on the camshaft sprocket is showing through a window at the BACK of the timing cover. It should line up with the edge of the valve cover, also driver side of the engine. If it's not showing then rotate the engine again until the flywheel mark is at TDC and then you should see it (the flywheel mark shows twice per one showing of the cam sprocket dot). If it still doesn't show then the timing belt may be off. I won't get into that unless you do have that problem.
Finally, verify that the distributor rotor is centrally located on the mark at the edge of the distributor housing or that it's centrally located on the #1 spark plug contact (should be the same, but you may not have a mark).
Now it's all at TDC and you can go from there.
To set the timing to the correct specification, first get the engine up to temp, so do it after a short drive or something. On this system you need to put a fuse (any rating) in the top of the fuel pump relay and wait for the engine light to come on. If it does, the ECU is telling you it's okay to set the timing. Leave the fuse in the relay for the duration of the procedure.
Now you can set the timing with a light as you would on any other car, using the (hopefully painted at this point) timing mark on the flywheel. It should be set to the vicinity of 14-16 degrees advanced, shoot for 15.
Then you can remove the fuse and rev the engine past 2500 and see how she idles. The idle speed is not adjustable on these, so if it's not running properly with the correct timing then that probably means someone set the timing incorrectly to get around a different problem, such as a vacuum leak. Now that you have the proper timing you can go hunting for that kind of stuff if you need to.
Whew, I think that's about it. Report back as to how it goes.![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
-Rog
-Rog
One thing that I found critical is the use of a timing light with either a manual or digital advance. There are no numbers stamped on the bellhousing, just a tab inside the bellhousing window that you use to line up TDC. With a timing light with advance, you set the dial on the light to 15° and then adjust the dizzy until the mark on the flywheel is aligned with the top edge of the tab in the bellhousing. I never saw a need for one of those lights until I bought my CGT. Otherwise your just guessing on where 15° is.
The NG engine uses CIS-E III and the above proceedure is ONLY applicable to these engines.
Not to start an argument, but you definitely have to set the timing between 13 and 17 degrees manually. The only way for an ignition system to automatically set the timing is if it has a crankshaft position sensor, which these don't have. Otherwise the computer has no way of knowing where the pistons are at. My Bentley manual gives a complete step by step for setting the timing, and it's all manual. The only thing that is automatically set on the CIS-E3 system is the idle speed. It actually states specifically that it cannot and should not be adjusted.
UPDATE: I've attached the pages from my Bentley manual describing the timing adjustment procedure for the CIS-E3 ignition system. You put a fuse in the top of the fuel pump relay, disconnect the crankcase breather hose, and set the timing. Because there are no numbered timing marks on the flywheel, you have to use a timing light with advance, as I said in my previous post.
radioboard
17
10-18-2006 04:23 AM
alfonzo312
Quattro: Turbo / Ur / Sport
02-26-2006 10:35 PM
metalv8
07-16-2004 06:57 AM
