Leaking Oil
Leaking Oil
I changed the oil seal 2 weeks ago when I did Tb/wp and I am still leaking some oil. I rarely ret a puddle, but everyrime I put it on the rack there is oil from the rear of my pan to the sway bar. Like it blows from somewhere when im driving. I am not using a Euro oil filter, could that be the culprit? Thanks.
Russ
85 4kq
Russ
85 4kq
Re: Leaking Oil
Do the 5 cylinders have the same oil cooler as the 4 cylinder, if so check the "O" ring between the oil cooler and filter housing. Mine was leaking under pressure and finally blew catastrophicly spewing much of my oil out. Luckily not before engine damage.
Good Luck
Packrat
Good Luck
Packrat
Bdybordr821
08-24-2010 09:02 PM
93_Audi_90CS
09-01-2009 04:56 PM
Dr.Duct_Mossburg
05-19-2007 05:55 AM
