not starting
ive got an odd problem. i was driving the car tonight went a few places, and then the car didnt want to start after a while. i turn the key on the fuel pump primes and then i tried to start it and nothing happened. it happened twice. any ideas?
Thanks
Thanks
Could be all grossed out, or look for a loose ground on the starter, I had one that got loose and would heat up and not start after driving around a bit.
nothing should happen when the key is turned I thought. This happened to me when I first bought my car. Turned the key and nothing happened. Nothing at all. Turned out a connector on one of the posts was loose and not making good contact. I just jiggled the battery lead till I had a good connection until I got home and tightened it.
"let me jiggle this and see what happens". Started right up. The fuel pump did prime, but it doesn't take much juice to do that. Hope it works better soon!
