Part numbers needed
Can anyone help out with some part numbers -
I need the numbers for the sway bar end link bushings - both the ones in the bar and in the control arm.
Thanks.
Thanks.
the easiest thing to do is go to Blau - they sell all the parts to r+r the sway bar in a package deal - endlinks, bar mount and the control arm part. Getting the bushings into the end of the bar (I did my 84 4KQ) takes a trick...at first you won't believe it will fit. soak the busing in hot soapy water then press one side in and while holding down on a flat surface work the rest in with a screw driver. It took me an hour for the first one and less than 5 minutes on the second (once I saw how it was done).
Sloooo4esT
Audi Original "S" Cars
08-22-2007 05:53 PM
AllGumption
09-10-2003 01:21 PM
Naudi2U
07-13-2002 11:10 AM
