A question for anybody that can help...
<center><img src="http://dtwaudi.com/album_pic.php?pic_id=1674"></center><p>Heres my airbox/fuel dist assembly for the MC motor once again. Since I had to flip the top of the airbox around to accomodate the igloo I also had to flip one of the large fuel lines (return or input), but there is still one line that needs to be flipped towards the rear. Its the large line visible at the lower left of the airbox. This line needs to face the rear so it can join with the other lines that go to the tank.
Anybody here know how I could do this? I did fiddle with the bolt and line to see if I could get it to work, but it doesnt seem like it wants to. A
Any ideas?
Mike
Any ideas?
Mike
Any idea where I can find the aeroquip lines, what site they would be on? Sorry for the kindergarden questions, just havnt been faced with the custom stuff before. Any BTDT on what size line/fittings to get? ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Thanks for the info.
Mike
Mike
If its 1/4" then use a #4 aeroquip line.
The Banjo bolt should be pretty easy to get with a barbed end. Then use a hose clamp or an aeroquip hose clamp end to dress it up.
If the Banjo bolt goes into a metric threaded hole, you can get Metric to AN-6 adapters and then an AN-6 90 degree hose end to accomplish the same trick and that would look very clean.
Lots of ways to do it with custom fuel lines.
James
James
escapA8
01-07-2006 04:05 PM
