Short shift kit for an 81 4k? Do they even exist?
Old 04-18-2003, 03:53 PM
'81 tic-tac's Avatar
Default Short shift kit for an 81 4k? Do they even exist?
<center><img src="http://pictureposter.audiworld.com/13228/shtrg.jpg"></center><p>Ive been looking for a while, and I'm not sure if I found what I'm looking for. I've been to a bunch of VW pages that offer short shift kits, but most don't look like my application. I found one which looks similar, but I'm not exactly sure. I have the reverse lock out. (means I have to push down to get to reverse) and the kit offered by qualityvwparts.com seems to be close. I added a picture of this kit. Any ideas? I believe it's off the A2 models. It would be great if these fit. Nice and cheap.
The link that I provided shows a short shift kit for about $100 for a Typ81. Would this be correct for my application? And is it worth the money?
Thanks a lot for any help!
-John<ul><li><a href="http://tuningzubehor.com/cfb.asp?pg=products&amp;lg=en&amp;vehg=3&amp;veh=7 1&amp;cso=1&amp;grp=231">Short **** kit possibility? (a little pricey)</a></li></ul>
Old 04-18-2003, 05:08 PM
AudiWorld Expert
MikTip's Avatar
Default You can DIY for much less! ;O)
Cut the shaft yourself &amp; rethread it! Its what I did on mine! Works great!
Old 04-18-2003, 06:06 PM
To rethread the shaft, what fancy tool do I need?
Old 04-19-2003, 12:11 AM
ddg=shinebox racing's Avatar
Default I have the same linkage you have.....
And I've never been able to find a kit. I looked at your link, there aren't any pics of the reiger kit, so I can't tell if it works or not. I modified the linkage on my old coupe by moving the pivot point up (the white pastic ball). I haven't tried anything on my current coupe, although I was thinking of replacing most of the rubber joints with heim joints.
Old 04-19-2003, 05:27 AM
rocketaudi's Avatar
Default a die!
go to the hardware store, tell the guy you need a die to cut new threads, hell show you these little nut looking dealies. find the right size and thread count (dont know off the top of my head, bring the shift lever w you and see which one fits) and there you have it. id recommend practicing on the piece you cut off first if youve never done it before, cutting good threads is an aquired skill. id also recommend some cutting fluid.
Old 04-19-2003, 01:45 PM
Max'sCoupeGT's Avatar
Default Check the spelling on your link
Quite humorous, I thought.
Old 04-19-2003, 05:28 PM
Haha, I didn't even notice... Works out tho, it is sh**, too expensive!
Old 04-19-2003, 05:29 PM
How did you manage to move the white 'ball' up?
The Librarian
Audi Original "S" Cars
11-26-2004 07:42 PM
YumyJager
9
08-02-2004 06:57 AM
Paul TTINGER
12-04-2003 05:04 AM
Quattrotrac
11
10-28-2003 03:32 PM
luvmyquattro
09-14-2002 05:22 PM
Quick Reply: Short shift kit for an 81 4k? Do they even exist?
