So someone had posted advice on how to smooth out the clutch pedal a while ago...
...but I can't find the post. What is the typical method for this?
It looks like my clutch pedal or pedal cluster might be bending from the 20 or so years of use.
Re: So someone had posted advice on how to smooth out the clutch pedal a while ago...
Check and see if your firewall is flexing when you depress the clutch. If it is, or if the firewall actually has a stress crack formed makingthe clutch even more rubbery, then you will likely have to buck up and spend the $100 for the custom plate that moves the clutch master cylinder off the fireall and clamps to the steering mechanism housing.
Contact Jeff Lewis the inventor/designer of this piece. NO one seems to be able to come lup with a cheaper solution, so buy the best and only cry once.
His email is jplewis@ucsc.edu
Max
Max
JayP
10
02-17-2008 01:01 PM
icys4
Audi Original "S" Cars
18
02-07-2008 01:50 PM
anb957
11-19-2006 05:13 PM
