Transmission oil
The usual procedure with manual transmissions/transaxles is that there are two plugs: lower one is drain, upper one is fill. To check level, just unscrew upper plug and check w/finger; proper level is right up to the top until the fluid starts coming out.
If you are draining and filling together, make sure you can loosen the fill plug before removing the drain plug. If just topping off, loosen fill plug only, of course.
Redline MT-90 is a redish bronze color vs MTL which is pretty red.
Think it differs depending on the oil used. ALl I know is that tranny fluid reeks
maxxrpm
01-06-2011 09:02 AM
Xel
04-19-2004 06:33 AM
AUDI 90 (88)
08-03-2003 12:24 PM
