Turning signal stopped working
Was driving and next I knew the turn signal stopped working. There is no blinking light in the dash, no sound and none of the lights outside work. I believe there is a fuse in the engine compartment and also a relay, not sure if the relay is in that box or under the dash, driver side. Hope there is nothing else like an in-line fuse or other relay. Many thanks
It was indeed that relay. And of course it had to be in a location that requires taking things apart, could not be in an easy to reach spot like in the box in the engine compartment or under the dash driver side
Hi Werner, nice to hear from you. Honestly I find the Audi and air cooled Porsches better designed than other cars. For ex changing the oil on a Jeep or a Maserati is such a messy affair I abandoned doing that myself whereas on an Audi or '79 911 it is a clean affair. Accessibility to many components is also much better. This relay though was not the best though
Which model are we talking about? I'm also having a turn signal(and backup lights, and high beams, and...) issue. I have a speedo and an analogue clock so relays behind the tachometer are a baffling concept. My relay seems fine, my fuse seems fine, my rear bulbs are working external of the circuit board, I can't figure out where my front turn signal bulbs even are...
(1982 4000 Diesel Manual)
StevenH
08-05-2022 10:36 AM
Zach, USM
03-30-2005 04:58 AM
