Uh oh....
All of a sudden on the way home from work, my car won't rev smoothly under about 3K rpm. It doesn't matter if it's under load( driving) or un-loaded (neutral), it shakes until you hit about 3K and then it 'clears' itself. I'm almost afraid that it's the fuel pump/filters that i decided not to change a year ago coming back to bite me in the ***. Any other things to check before I dish out the $$ for the filters and/or pump?
if the pump wasn't making enough pressure you'd have a hard time revving or would stall under load. I'd look for something that would impact the mixture or the burn rate like O2 sensor, temp sensor, possibly a FI pressure regulator etc - but my first stop would be to inspect the air boot, vacuum hoses and ISV... Next I'd check the plugs for fouling, the wires and the rotor and distributor cap (a good trick is to mist the wires and cap with water then start it in a dark garage - Little blue arcs are bad... Then I'd move up to sensors like the O2 and temp - last I'd suspect dirty injectors so throw some injector cleaner in the fuel tank...
I'm not really sure. I had read that CIS-E will sometimes run full rich without the o2, but sometimes run full lean. I've been wondering if 1: that's true, and b: what my car is doing.
Tim Baker
13
03-14-2023 03:20 PM
road2speed
09-15-2012 02:00 PM
