Updated Pics: Projects Finished
Finished putting in Ground Control coilovers, rear sway bar, and Euro headlamps.
<img src="http://pictureposter.audiworld.com/24776/aerial_shotfor_post.jpg">
I'll admit, I bought the headlamps mainly for cosmetic purposes but the lighting capabilities with the "high wattage" bulb package are incredible. Turned night into day... Rear sway bar finally killed the unbearable body roll; highly recommend it to anyone tired of the CGT's or 4k body roll.
<img src="http://pictureposter.audiworld.com/24776/side_shotfor_post.jpg">
87.5 CGT
Black Leather Int.
Blaupunkt Heidelburg CD Player
Infiniti Kappa 3 1/2's in front
Kenwood 4-way 6x9's in back
Alpine 5-channel amp and Blaupunkt 10" in trunk
Alpine SEC-100S Security System w/ keyless entry
Euro Healamps
Tinted Tails
Yokohama Parada Spec 2's on 16" Borbet Type E's
Ground Control Coilovers w/ KYB gas strutz shox.
2.25" Exhaust w/ high flow Cat and center mounted magnaflow muffler and polished stainless steel dual tip.
Turbo Conversion on the way. I'll keep you guys up to date on that adventure.
87.5 CGT
Black Leather Int.
Euro Healamps
Tinted Tails
You have to provide enough information or supply them with a stock rear shock assembly in order for them to "custom" make a package for you. They offer a set for 4kq's that have a near identical front strut assembly. To install the front, you must remove the lower spring seat on the housng that the replacement strut cartridge is placed into. Then weld on the supplied seat that the threaded adjuster will sit on. Didnt prove to be as big of a task as I had thought.<ul><li><a href="http://www.ground-control.com">http://www.ground-control.com</a</li></ul>
Car looks great.Do Euro headlamps fit straight in place of US style healdlamps? Are US lights same as 88 80 saloon lights> I'm contemplating replacing my Eurolights (rusting reflectors) with cheaper readily available (here in NZ) 80 saloon lights
Ross
Ross
The euro lamps fit in where the US ones do, but you need the metal brackets that hold them, and obviously the wiring needs to be changed somewhat. The 4k and 4kq US are the same parts as the CGT 85-87.
Have you had your car painted? I have been thinking about painting mine, but I am not sure if you can paint the rear wing. I also want to remove the door bumper guards and entirely paint the front and rear bumbers. Anyways - your car looks great!
