Upper Strut Bar???
Where can i get one? It seems the only place to get one would be ebay... when one happens to come up. 1984CGTTurbo where did u get your universal bar? and i read u got a new bar? If so can i get dibs on the old one? Also If i make brackets and put a bar between my rear tire wells could that be like a rear upper bar? or am i just stupid?
It's a Jamex universal kit. I recently acquired a set of DW front & rear upper strut bars and will be having them installed later in the year. A far as selling my existing one, maybe but I currently intend on using it in my 4KCSQ. However I may be getting a different car by then so if it available I'll let you know.
BTW 2B has SPARCO strut bars available still check with them if you need one sooner.
J.
The straight one works fine in my car, but the battery is in the trunk so it's not a clearance issue.
<img src="http://pictureposter.audiworld.com/21637/mc1.jpg">
J.
The only commercially made one I know of is Jamex, and it's been out of production for many years. It's aluminum, and is bent to go around the battery. They are a little difficult to make for the 4k as there are several things that prevent it from going straight across.
The rear one is probably a waste on a CGT as the rear bulkhead serves the same purpose.
Ramsey
06-06-2008 12:47 PM
Hokie - STI avant
09-23-2001 06:39 PM
Dmak
Motorsport Discussion
05-17-2001 05:40 PM
