VDO Oil pressure and temp senders help needed...
I have a 84 4kq and I am trying to put the VDO guages.
Where can I put the Oil pressure sender? I can't find an open oil galley or a plug to remove.... And how exactly does it wire up? The sender has two posts one marked G and one W (I think). And the gauge has one marked G(I think) Is the sender supplied with power? then wire the G post to the G terminal on the Gauge? Or is it grounded?
How can I get the Temp gauge working too? I suppose I will need that sender as well??? Where does it go/ come from?
Please help if you can, I have a million other projects going on too before I can get this dash back together and the car all ready for winter.
Also, anyone looking know how to get the Power window switch lights working if you swap in some from a newer 1990s Audi?
Re: VDO Oil pressure and temp senders help needed...
Okay, so I tried the search and figured how to wire the Oil pressure gauge. Now I just need to figure the oil temp gauge out...
Re: There's a whole page about it on huw's site
Yeah, just thought to look there. But he already had th wiring in place for the temp gauge/ no more details about it...
Dude.... look no further... Jerky's got all the answers!!!!
Question, are you using the stock audi (VDO) gauges or off the shelf VDO??????
I found out the hard way the stock Audi senders aren't compatible with the aftermarket VDO's and vice a versa!!!
In the pic below are the sender on top (little can)
and the idiot light sender below it:
<img src="http://pictureposter.audiworld.com/41804/imag0024.jpg">
eelpie
02-05-2007 02:51 PM
BigMouse
Audi 100 / A6 (C4 Platform)
02-03-2006 10:26 PM
'81 tic-tac
06-01-2003 12:41 PM
