Weak brake pressure (whats up with the vac pump on the side of the block?)
Ok so on the 84 4kQ the brake pressure is super weak. COming to a full stop means putting th ebrake to the floor.. almost. If you pump em a few times itll brake a bit sooner. Anyways I am wondering if the brake booster is getting any vacuum, and while I havent sprayed chem tool all over everything yet I do know all the vac system components and lines are intact. Which leaves one thing in between the booster and the intake manifold, a T junction connected to the dreaded ticking vacuum pump (this one actually doesnt tick, and considering it sat for three years I am figuring it isnt working...)
Any harm in bypassing the vac pump and running the vac for the booster directly off the manifold? Again i havent taken anything apart yet but would like to arm myself with knowledge before attacking. Any insight greatly appreciated.
I do understand that it could also be a hydraulic air bubble of some sort but figured I'd start at the easy stuff to reach to
The brake proportioning valve mounted under the master cylinder likes to spring a leak after a few years. Also the master cylinder might be leaking internally (fluid seeping around the seals inside). It could simply be air in the lines too.
a vac leak there? I wasnt sure if the pump is sealed within itself or not...
UrScubed
Audi Original "S" Cars
05-10-2006 10:30 AM
