Went to drive home from school and my car wouldn't fire up?........
Old 04-23-2008, 02:27 PM
audithepeanut's Avatar
Default Went to drive home from school and my car wouldn't fire up?........
Battery is good, fuses all good ("spare" included)
It always starts rough when its cold, so i have to crank it for 15-30 seconds or so and pump the gas pedal and then it fires up, If I sit there and let it warm up for a minute or so then it's good and it'll run like a champ.
Today however I went out to my car, did the whole routine, it fired up for about 5 seconds then sputtered out. i repeated the procedure to no avail.
It turns over but won't fire, what could have caused this? It ran fine this morning...
Old 04-23-2008, 02:34 PM
New Member
Shadowfax's Avatar
Default Mine did that once, needed plugs,rotor and dizzy cap.
I hope that's all yours needs, not enough info to diagnose further.
Old 04-23-2008, 02:38 PM
NJRoadFan's Avatar
Default Reseat the fuel pump relay....
It worked for me when my car wouldn't start. Relay #9 in the fuse box (a tall one).
Old 04-23-2008, 02:39 PM
Default All system are go except for spark it seems...
Fortunately the old girl already has an appointment with the mechanic.
Unfortunately its not until may 5th.
Fortunately its only 2 miles way from my house, so if I can get it to start just tonight, then it can wait two weeks....
Is there a way to "force" it to start?
Old 04-23-2008, 02:40 PM
Fuel pump whines when key is turned, would reseating it still help it fire?
Old 04-23-2008, 02:44 PM
NJRoadFan's Avatar
Default Likely not....
The relay is working fine if the pump is running. Check all electrical connections in the engine bay anyway. The hall effect sensor is a popular one to cause starting problems. The usual routine applies, check for spark and check for fuel.
Old 04-23-2008, 03:12 PM
New Member
couper83's Avatar
Default close to my dilema when my CGT did that...
ended up being the hall sender, but i put a new rotor, cap and slugs in and then the fuel system took a dump but it is running now
i never new those cap screws on the fuel distributor came off and under them where the fuel adjustments for each cylinder, it sure helped me
Old 04-23-2008, 03:40 PM
New Member
iamMRAUDI's Avatar
Default I had a Coupe that used to eat coil wires..........
Pull it off both ends and make sure is is intact
Old 04-23-2008, 04:31 PM
Default Went back down, checked for spark and fuel, both good. Looked at intake boot...
and it had somehow come disconnected on the backside. put it back on and she fired right up
Old 04-24-2008, 03:55 AM
Whitjr's Avatar
Make sure that there's no moisture inside the dist cap! My 4k gets moisture in there periodically..
Quick Reply: Went to drive home from school and my car wouldn't fire up?........
