What to do with your AC after removing it.....
Well the cool thing is 87 4000cs' came with the York 210.... This is probably the best compressor for an OBA or on board air system for your Jeep. I am planning on making some brackets and using it in my XJ to fill tires and run tools. I went on a run with someone that has it and it truly is the best way to go.
So I started thinking..... all the brackets are there for the Audi.... why not make an OBA out of the extra York I have for the 4K..... I just don't know if saving the weight or having the air is better.... what say you guy's????
Here is a link....<ul><li><a href="http://www.stu-offroad.com/otherwriteups/oba/oba-9.htm">York 210 OBA</a></li></ul>
Filled up 4 35" tires from 8PSI to 32PSI in about 7 mins..... In Jeep time that is fast. The dudes running the electric set-ups (me) take at least 15-20 mins to do the same if not longer. The 210 has been used in the off road community for years in this application. Run it to a 5 gallon tank and it will run air lockers, tools, etc. It works at about 120PSI max.
Here is another good write-up:<ul><li><a href="http://www.webejeepin.com/Glenns_Jeep/onboard-air1.htm">More OBA</a></li></ul>
spdrcrpete
12-08-2004 06:29 PM
