Where is the cold start valve?
im having fuel cutout issues and I've tried damn near everythingelse.
New fuel pump, fuel filter, coil, unplugged the WOT plugs, new fuel pump relay, bypassed the fuel pump relay...nothing has solved this problem yet.
Thanks
Thanks
Re: Where is the cold start valve?
on intake, the other injector line, has electrical connector. only operates when starting for a few seconds. What kind of fuel pressure do you have?
You'll have six silver fuel lines running from the fuel distributor on a five-pot engine. Just follow the five to the injectors all lined up in a row, and the sixth that doesn't go to the injectors, runs right to the cold start valve (CSV).
just like a rabbit man. check pressure then volume then balence between the 5 and then go from there (are you the guy that has the yellow corrado in pdx or somewhere around there?)
audi90jada
03-05-2007 06:16 AM
