Window Stuck
Went through drive thru. rolled down the window, crackling sound. tried to roll it back up, got stuck 2 inches from the top. cant pull it up.
is the only option to take the door apart?
I had the same thing happen, and when I opened up the door panel I found a tangle of cable (from the regulator) and ended up having to hold the window up with a bolt until I could get a new one. That's one of those things that I wish they had designed better, along with the outside door handles and the clutch slave...
-Rog
-Rog
Well, the Coupe/urq regulators are unique to these cars. Any year Coupe GT/urq will use the same regulator, as the doors remained the same throughout the model years. There are also aftermarket (worm gear style) replacement regulators available. AutohausAZ sells them. Looks like they sell for around $160 a piece. Here's the link:
http://www.autohausaz.com/search/pro...=1009000@COUPE CUSTOM&year=1985&cid=13@Body, Trim %26 Lighting&gid=10217@Window Regulator
And these after market models require a little modification to make them work. They work well enough, once they are installed. And you no longer have to worry about cables disintegrating like on the OEM models.
I hope this helps.
Good luck.
Ted H.
86 Coupe GT
90 V8 quattro
98 Volvo C70 Coupe HPT Manual
I hope this helps.
Good luck.
Ted H.
86 Coupe GT
90 V8 quattro
I bought a new window regulator, but where the window clip and window regulator come together, the holes didnt match up. so im wondering if anyone else came into this problem? how did you fix it. if possible, pictures?
32Valve
01-22-2008 06:36 PM
rbuckstar
05-22-2003 09:25 PM
ondo
06-24-2002 10:08 AM
