1988 audi 5000s quattro random no spark issue
Old 03-19-2012, 03:56 PM
  #31
audiqv8's Avatar
Earlier you stated that you replaced the distributor. Did you ever reset the distributor timing? Follow your Bentley on how to reset distributor timing.
I recall on the turbo model that the cam (hall sender) and the crank sensor must be in sync before the ECU will send a signal to the coil to produce a spark. If the cam and crank signal were slightly out of sync then the ecu will not send the signal to the coil.
Old 03-19-2012, 04:35 PM
  #32
nize's Avatar
i never replaced the distributor, i did replace the distributor cap and rotor. do you think it may be time to replace the distributor itself?
Old 03-19-2012, 06:06 PM
  #33
audiqv8's Avatar
I would verify if the distributor is timed correctly. Perhaps you moved the distributor when doing the rotor. You can place a reference mark on the distributor housing and try rotating it either clockwise or counter clockwise and see if the engine will start.
As I recall there are no codes stored when the crank and cam signal were out of sync for the turbo engine. The ECU will see both signal, but they would be out of sync and it would not send the trigger signal to the coil.
Old 03-20-2012, 06:30 AM
  #34
audiqv8's Avatar
Read the entire link
https://www.audiworld.com/forums/sho...ht=hall+sender
Old 03-20-2012, 03:30 PM
  #35
nize's Avatar
that is an interesting thread. in my particular case, i'm wondering why it will sometimes start up and run just fine after sitting for a while when i have not touched anything. i would think that if the distributor was out of alignment, it would never start/run.
in any case, i'll re-inspect the distributor and rotor again just to be triple sure something isn't out of whack in that area. thanks for the link!
Old 03-20-2012, 05:51 PM
  #36
audiqv8's Avatar
Either your distributor is timed incorrectly or the hall sender inside the distibutor is about to go out.
Old 03-26-2012, 07:17 PM
  #37
upallnight's Avatar
Had a 4000 CS Quatrro and it was the Hall sender that cause the engine to die while running and to not start afterward.
Distributor Hall Effect Sensor and connector (10V MC Engine)
Remove the three terminal connector from the distributor for the hall effect sensor, using a DMM check for ~12VDC, (at least 9 Volts) between terminals 1 (Red/Black wire) and 3 (Brown/Red), the two outer connector pins with the ignition key on. Pin 1 is the first terminal on the left with the spring release clip wire towards the top. The 10V Engine ECU supplies ~+12V to this hall effect connector at pins 1 and 3.
NOTE: The 20V 3B engine Hall Effect sensor will only have 4.5 to 5.5 volts between Pin 1 and 3 as the Motronic ECU only supplies approx. 5VDC to the Hall Effect Sensor
Check the connection in the plug from the hall sender on the distributor. In some cases the female contacts may be loose and are not making a good connection. Use a small dental pick to push the terminals together to ensure a good tight connection. Re-install this connector onto the distributor connection.
Use a DMM and check for low (<1.0 ohm) resistance between pin 1 and engine ground, in one case, resistance between this terminal and the ECU caused a no start condition, even though 12V was measured across pins 1 and 3.
Peel back the rubber boot on this hall sensor connector and connect a DMM to terminals 1 and 2 with the ignition key on. The voltage measured across pins 1 and 2 will be ~4 volts when the distributor hall sensor is shielded by the metal cover (hat) on the distributor shaft. The voltage should be between 0-0.5 volts when the hall sensor is not shielded by the metal hat. You can remove the distributor cap, and slowly rotate the engine around while you watch the voltage measured at pins 1 and 2.
A better test for the Hall Effect Sensor, is to make up a "low voltage" LED test light (LED with 120 ohm resistor in series) and connect the positive (+) side of the LED test light to terminal 1 (Red/Black wire) and the negative (-) side of the LED test light to terminal 2 (Green Wire) of the hall effect connector. This test is done with the connector plugged on to the distributor connector, and by pulling the rubber boot back off the connector to allow back probing the connector terminals.
The low voltage LED test light should flicker on/off when you crank the engine over during starting to indicate the hall effect sensor inside the distributor is working correctly.
Old 10-13-2013, 11:42 AM
  #38
nize's Avatar
i thought i would update this thread. i finally broke down and brought the car in to an independent german car specialist, explaining all of the various things i've tried to fix this so far.
he ordered an ignition control module (DME/computer in the footwell) and after swapping it, the car runs like a champ and starts up every time!
i don't think i would have ever figured this out on my own.
thanks to everyone on here for their suggestions!
calleth
05-13-2009 02:51 AM
Pieter
Audi 100 / A6 (C4 Platform)
02-06-2009 08:23 PM
matus08
2.7T V6 Discussion
03-22-2008 07:21 AM
einnod17
30v V6 Discussion
9
01-10-2008 05:20 AM
Fanaudical
09-16-2007 09:52 AM
Quick Reply: 1988 audi 5000s quattro random no spark issue
