1990 V8 - Diagnostic Code 4343?
4343 Carbon Canister,
Open or short circuit
Symptom: Poor response in part of load range, fuel odors, idle speed affected
I'm getting code 4343 when I run the codes on my 1990 audi v8.
Anyone know what might be causing this?
Thanks,
Tomek.
Thanks,
Tomek.
The carbon canister solenoid valve maybe shot.
Checking:
remove the 3 screws for the coolant tank, & place it out of the way..leave the hoses connected.
disconnect solenoid harness connector.
use a MM set to resistance range
connect meter between the valve terminals...must be 40 to 50 ohms.
If not replace the valve.
If the valve shows it's OK...then you have a wiring issue.
Checking:
So I checked where you said, sure enough found a sensor there.
I tested the resistance an its around 80omhs...
Also, I have 2 of these V8's and use one for parts. I swaped the sensor from the 'parts' car and tested it, it showed around 80ohms too.
Is 80ohm ok?
Is 80ohm ok?
So Iv read up more, what I need to replace, that is if 80ohms is no good:
http://corrado-teile.de/shop/product_info.php?info=p2240_Solenoid-Valve---BOSCH---VR6-Engine.html&XTCsid=7e73e43088f1cd69fc6e1b94360 935eb
Says here its good for VW Golfs, Jettas etc, so I'm assuming one of the 'big' parts retailers locally will have it. I'll be getting a new one tommorow, please let me know if 80ohm is no good.
Thanks,
Tomek.
Thanks,
Tomek.
dudleydorighta4
02-08-2005 10:42 AM
Tiblet
01-27-2005 08:23 PM
