1990 v8 quattro transmission problem?
#21
Well the news is not good from the home front I have been told that I need a new transmission or rebuilt. As you read in the tread that I had been having problems with the AT and finally shipped if to an import repair specialist. They did manage to get the car to move in both directions but I have been informed that the trans was gone or about to go completely. Now I do not trust any repair shop which is why I do most of the work myself and I kind of trust this one but how do you know, which is why I would like any opinion on what you would do. Should I drop the pan and replace the filter and fill with fresh fluid and see what happens? What if it is just the transmission control module how would I now and what should I check for? I guess that I don't want to believe a new or rebuilt transmission is needed.
If I need a rebuilt one, where would be a good place to look? I was told that there 3 styles of transmissions and my code is (ATU) also If I can, I would like to rebuild the one I have but not sure where to get the parts needed. Any help is appreciated.
The estimate to replace with labor is around 3000.00USD
#22
"If it were me".
For the cost of some fluid and a filter (and a bit of time). I would change the filter and do a flush. For the $50.00, it could save you $3000 if you have someone do it, or a few hundred for a used one, and several hard hours in swapping it out.
Details on where to get the internal parts.. cheap.
For more information contact us at:
786-472-8500
786-486-0335
Info@CobraTransmission.com
www.cobratransmission.com
Transmission Parts and Rebuild Kit Prices:
ZF-4HP24A
1990 - 1994
Overhaul Kit ZF4HP24 (88-Up): 147.99
Banner Kit ZF4HP24 (88-Up): 194.99
Master Kit ZF4HP24 Audi V8 AWD: 283.99
Filter, ZF4HP24A Audi (89-94): 9.99
Valve Body Kit (Shift Kit) ZF4HP22 Dealer: 43.99
Valve Body Kit (Shift Kit) ZF4HP22 Sonnax: 11.99
Technical - Repair Manual: 32.99
Torque Converter: Please Call
Prices in US Dollar, Shipping World Wide.
786-472-8500
786-486-0335
ZF-4HP24A
1990 - 1994
#23
"If it were me".
786-472-8500
786-486-0335
ZF-4HP24A
1990 - 1994
786-472-8500
786-486-0335
ZF-4HP24A
1990 - 1994
John
#24
HHMM, that's why I said, " Drop the fluid and pt in 1 gallon" This IS the preferred method for swapping out what is in the pan and making sure level is OK. For a flush, then I'd take your route.
You mentioned, "when you do a atf change you are supposed to put in the exsact ammount that you take out"
Again, what is the point of this? If you are 1 qt or 2 low, then you will still be low if you only replace what comes out! Draining via the pan, and filling with one gallon, will get you to proper fill levels than take it from ther.
i dont think that its a good idea to be telling him to put exsactly one gallon in. since its pretty hard to tell whats in there now! not to mention that when you drain out the automatic transmission it doesn't completely drain. when you do a atf change you are supposed to put in the exsact ammount that you take out, (assuming the tranny has no leaks of course) from what i was told when doing an atf change is to drain it out, till it stops draining, start the car BRIEFLY! for about 30 seconds max just letting it run in idle, which will allow more atf fluid to drain, (if the fluid slows down on draining while the car is running shut it off. have somone watch it drain. then fill and repeat one more time. i did do this to my 1990 auto v8, and it worked perfectly fine no damage or anything. if any higher up grurus ie scott and ron want to argue this method then i seriously encourage you to listen to them and not me.
#25
StigB
08-21-2013 06:02 AM
Bubuski
12-15-2002 09:39 AM
