1990 V8Q Power Door Locks have become inop
I just checked fuse #19 (10 amp) and it is ok., I check for any relays in the passenger footwell (none). . . any ideas as to what would all the sudden cause the central doorlock system to become inop?
Thank you,
Rein
Thank you,
Rein
I can get all the doors to unlock from the passenger side only after the drivers door has been manually locked. After this, I cannot relock all the doors unless I go over and manually lock the drivers door first then the passenger door (which will lock the remaining three doors and the trunk).
So that is my trouble.
I look forward again to your help. With 255K+ on the clock, the Second Law of Thermodynamics is playing an ongoing role in maintaining this car.
...or the actuator has a leak.
I'd put a small amount of air through the line & check to hear if it's leaking.
saullyb
08-17-2012 06:03 AM
