5 speed transmission.
Hi guys!
I was wondering if anyone has the dimensions for the 5 speed manual Quattro tranny. Length from the bell housing to the front and rear drive shafts. I also would like to know the gear ratios. Thanks in advance!
Audiworld has historical records for all technical specs of these cars. Go to Model guide- Historical.
5 Spd Gear ratio for 86-88 5000 CS TQ
1st- 3.60:1
2nd- 2.13:1
3rd- 1.36:1
4th- 0.97:1
5th- 0.73:1
R- 3.50:1
Final Drive- 3.89:1
5000 S (non turbo)
3.60:1
2.13:1
1.46:1
1.07:1
0.86:1
3.50:1
3.89:1
1st- 3.60:1
2nd- 2.13:1
3rd- 1.36:1
4th- 0.97:1
5th- 0.73:1
R- 3.50:1
Final Drive- 3.89:1
5000 S (non turbo)
3.60:1
2.13:1
1.46:1
1.07:1
0.86:1
3.50:1
3.89:1
Of course if you spool all the torque to one wheel (lifting the inside rear, without diffs locked) you can break stuff upon making contact with the ground again. Also BTDT.
So whatever the 1995 'Vette LT-1 produces in torque is a known quantity. But I NEVER took it to a 1/4mile. I think that would have killed it, I only romped on it once the gear was engaged.
Hasn't been fully updated in sometime.
I have some pics of the car after it's done that I took at Grattan raceway. I'll have to look those up if you want.
Steve
Michigan<ul><li><a href="http://www.msu.edu/user/dupreer1/flyinghead/index.html">http://www.msu.edu/user/dupreer1/flyinghead/index.html</a</li></ul>
Steve
