5000 cs Megasquirt
Hey guys.
I was wondering where can i find the megasquirt setup to upgrade the EFI on my 5000cs. I know about the stage II setup 034motorsports sells but i heard that megasquirt is alot cheaper than that.
thanks paul.
thanks paul.
www.msefi.com
I will me building several in a month or so I could add another if you would want.
You really just need to piece it together, there is not really a place to buy all of the parts and just install it.
Ask specific questions and I can help,
Jim Bush
Holland, MI
Jim Bush
Holland, MI
allright. What do you charge for the hole setup or what price does it run for everything. And then on the wireing how does that all work, sice your not useing the old EFi distributor type thing?
Hmm ive never seen any 034 audi 10v ecu's on ebay. One day surfing the net i found this http://filebox.vt.edu/users/jdubyk/Audi/EFI/EFI.html but i wana know what all part you need to do the swap.
at the minimium a low band AF gauge, would recommend wideband though. Gut out all the CIS fuel system including injector lines WU regualtor and air box. AN fittings are needed, also do you plan on using the original stock ECU for ignition or are you going with fuel and ignition with the EFI setup? If so, ditch your distributor and get 5 coil packs as well. SEARCH the forum archives here, all this has been posted over the years, Search for Adam Mowafy's posts he did a very nice EFI swap, Birmant too, Steve Ankney did one as well thats off the top of my head. ALSO check and search the forums at MG's website. HTH.
nickelmedia
06-26-2006 02:57 PM
Kllrbee
11-11-2002 03:13 PM
