5000S KZ no start : Help!
I removed the exhaust, recharged battery, and got
the same problem : cranks but does not start.
I have OK FPR/CSV/pump, spark, ICU, coil,
plugs/rotors/timed-to-spec/dizzy OK, compression/
plate/plunger.
Is it normal for a properly-timed engine to
backfire every 5 cycles (i.e. if it doesn't
start) ? I disconnected fuel pump relay to prevent
flooding.
Also, anyone have a photo of where the coil ground
wire connects to the valve cover/engine block ?
TIA
plate/plunger.
flooding.
TIA
Re: 5000S KZ no start : Help ,
I don't understand ... Did you 'disconnect the fuel pump relay' before you tried to start? If yes, that might be an issue.
Backfiring might be caused by incorrect valve timing.
Re: 5000S KZ no start : Help!
Spray starter fluid into the air intake...
If it fires up then it's most likely a fuel issue. If it doesn't then it's a ignition or timing issue...
Steve
Michigan
Steve
Michigan
wallaceno1
22
10-09-2008 05:13 PM
Randy 5ks
01-03-2006 10:36 PM
Snopyro
08-23-2005 09:02 PM
