5cyl turbo Megasquirt users....
I'm running megasquirt on my 20vt (3B) and am looking for some examples of fuel/spark tables and other misc settings.
I've got V3 ecu with MSnSe. Anybody using the same ECU setup on either a 10vt or 20vt? I'd really like to take a look at your .msq files. If you could email them to me, I'd really appreciate it. The email address here on AW works fine. Thanks a lot!
I am thinking about getting VEMS. How do you like your megasquirt setup? Check vems.hu. There is a guy on there who is running VEMS on his AAN motor. I think he has the tables posted for the setup. IIRC Megasquirt and VEMS use the same software--Megatune so his tables should work for you. Email me if you can't find them. And email me to tell me about your megasquirt if you have time.
other than stock. Beats the stock ECU, no problem at all.
Downloaded the files from a guy running VEMS on an S6 in the wiki on that sight you mentioned. My Megatune is having trouble opening the files. ONce it opens them, everything is blank, and after many errors during loading. Any tips? I find the right guy?
<ul><li><a href="http://www.vems.hu/files/MembersPage/MiskaPeippo/AudiS6/mct.txt">http://www.vems.hu/files/MembersPage/MiskaPeippo/AudiS6/mct.txt</a</li></ul>
Used notepad to view the .msq file. (http://www.vems.hu/files/MembersPage/MiskaPeippo/AudiS6/s6_09-oct-2006.msq)
His tables are 14x16, I manually truncated them to get 12x12 tables. Downloaded them into my MS and it started right up, idles nice and smooth, although the power isn't what I'm used to (with the same MAP). Very smooth though and certainly not slow. I like.
Before now, I was using the setup file that I made from scratch using the tutorial on the megasquirt.info site. Ran fine and was very quick but my ignition timing wasn't quite right, so idle was a bit rough and transitions between acceleration and coasting resulted in some nasty burbling. These tables run much nicer, but the power isn't quite what it was before. At least now I should be able to up the boost a bit.
you seem to have all the answers I need.
everyone said contact you I am looking at MS and I have a 3b that I need more power from
please contact me at mike@euroteknique.com
I want to know what setup is needed for Ms and what modifications you needed to make it work
this would be greatly appreciated I thank you in advance.
XCCESS
02-06-2004 04:15 PM
No More B5 S4
08-12-2003 07:16 PM
Liam in Montreal
Canadian Discussion
06-30-2003 06:26 AM
WYSIWYG
05-19-2003 11:19 AM
Yippers®
10-01-2001 02:10 PM
10vt, 20v, 3b, 5000, 5cyl, a3, audi, cyl, distributor, ignitionsport, install, megasquirt, megasquirtrs2msd, quattro, turbo
