5ktq wheel bearings
Does anyone know if the 100/200 wheel bearings are interchangeable with the 5ktq? I know the 5ktq takes a bearing with 85mm outer diameter for the front and I think the rear also (maybe). Also, does anyone know of a source to get the bearings for less than $50-- like a bearing shop. That just seems a little steep for a bearing.
not sure if the 100-200 interchangeable with 5K, but go to a good parts online site and call up different models to see if the part is the same.
like a number ie. 3208 which is the bearing size, followed by some letters ie. ZZ or RS which would indicate what type of material (rs=rubber shield) anyway, you need to get the ID, OD and width if there is no number. I'm sure they are shielded and have synthetic grease. See if there is a C3 or C4 designation. C3 is normal and C4 has more clearance. I repair German (Becker and Rietschle) pumps and motors (to 25HP). The bearings are avilable at most bearing suppliers but I can cross ref. Love to know because my rear is humming (boy, that don't sound right!) and will need replacement soon.
justinm0424
08-25-2008 12:57 PM
