86 5000 TQ air filter
Could someone tell me the easist way to change the air filter in this car? Also, Which brand/model spark plugs are good to run in this car? It's stock except for a TAP chip and adjustable wastegate.
thanks in advance
thanks in advance
For plugs you can use Bosch W7DTC or NGK BP6ET spark plugs. Both are tri-electrode and the Bosch are OEM. I am using the NGK's with no problems. To remove the air filter, start by taking the pipe from the air boot to the turbo off and then take the intake scoop off the airbox. Then you just take the side off the airbox and change the filter.
dzywicki
04-28-2013 09:03 AM
jfk92
01-30-2006 06:49 PM
Mr Paul [T-28]
12v V6 Discussion
05-07-2005 09:46 PM
