86 5000S Speedometer
Old 02-01-2010, 06:42 PM
  #11
yota-toy's Avatar
My '86 turbo has no cable, my '88 non turbo uses a cable. If mileage is calculating it's not the pick-up. Like 68 said, check connections!
Old 02-08-2010, 03:56 AM
  #12
johngotts's Avatar
The car has a speedo cable (very light brown off the top of the differential). I suppose this is more of a engine code driven option (KZ)being that there a so many different answers.
So I guess the question is (before I pull the cluster), since I do have a speedo cable, is the speedometer indicator mechanically or electonically driven by it? Don't forget, the odometer is working, and that is my source of confusion.
Old 02-11-2010, 12:11 AM
  #13
greattik's Avatar
Just try with an electric pulse that comes to the speedo head, that the speedo control board interprets. It makes the odo motor turn, and generates a magnetic pulse which moves the needle.
Old 02-16-2010, 08:02 AM
  #14
johngotts's Avatar
So, I detached the speedo cable at the differential, spun it by hand, and the speedo operates. I guess that means there's something in the differential (plastic gear?) that operates the cable. Anybody know of this?
Old 02-22-2010, 03:47 AM
  #15
johngotts's Avatar
So, I answered my own question...
At the end of the speedo cable in the differential mount, is a removable shaft that has the plastic toothed gear on the end. It's easy to take out, one screw on the top of the differential that holds a retaining bracket for the gear, and out it slides. BTW, I also found that on the back of the instrument cluster, there is a mechanically resetable pawl for the OXS sensor that turns on every 30K miles. You just push the pawls forward and it resets the light. The pawls are accessible through a small square cut-out at the top of the cluster above the speedo head. It's labeled "OXS" by the cutout.
albion21
06-01-2009 03:01 AM
lleiro
Audi 100 / A6 (C4 Platform)
05-06-2007 12:13 AM
88audi90Qattro
09-22-2003 02:18 AM
Robert 100E
Misc. Models Discussion
11-02-2002 04:55 AM
Ben's e//S2
02-14-2002 09:24 AM
Quick Reply: 86 5000S Speedometer
