ABS Sensor issues
Old 07-01-2010, 08:45 AM
  #11
bronxnativ's Avatar
Hey Scott,
Do you know if these super cheap sensors will work on a B3? (1988 Audi 90Quattro).
Thanks!
Old 07-01-2010, 12:08 PM
  #12
Kneale Brownson's Avatar
If the sensors meter out OK, you could have rusty teeth that the sensor reads. There's a little hole in the bottom of the axle housing where you can just see a tooth or two at a time. If there's rust crud between the teeth, it'll cause the same kind of performance. Kind of tiresome to clean one tooth cavity at a time, but you can do it quickly if you pull the axle.
Also check the dimensions of the truck sensor. I think those fit 89-on Audis, which have a different mounting system than the earlier Type 44s, which require the ablative plastic cap to set the proper depth. The later cars have a ledge in the housing against which the sensor fits for proper depth (and require you clean that out well to get it just right too).
b5s4blk
11-14-2008 05:02 AM
onyekachi
05-25-2005 01:53 PM
treasurer
10-14-2003 12:25 PM
jif
Audi 100 / A6 (C4 Platform)
05-26-2003 10:11 PM
Quick Reply: ABS Sensor issues
