Adjusting CO and Idle, MC-1 engine
Hi,
I decided to check/adjust idle/co mixture on my car. Of course the first thing I did was look at SJM site for a complete instructions, and I didn't really understand what he means by "Disconnect the breather hose coming from the air intake boot at the valve cover tee fitting and plug this hose". Could somebody please post a picture of the exact location of that hose? Also there it says to take the cap off from the plastic tee fitting near the R/Front head lamp, mine tee fitting is broken/missing, so these two hoses are just joint with a regular plastic pipe. Is it really bad? will it affect the adjustment? I'll replace it with the proper parts of course if it's really important.
Thanks in advance,
Sergei Pokrovsky
'87 5KCSTQW, 188k miles
getting prepared to QLCC kit
Anchorage, Alaska
Thanks in advance,
Sergei Pokrovsky
Anchorage, Alaska
There is a "t" on top of the valve cover near the back that connects to another hose that snakes behind to the intake boot. They want you to disconnect that hose from the t and clamp it shut or plug it.
<center><img src="http://pictureposter.audiworld.com/52898/vag01c03.jpg"></center><p>if I got it right it must be this one, #1 on the picture, correct?
mAgnum8
08-26-2008 06:22 PM
TTington
08-22-2008 08:18 AM
