After all of those months and spent money (ALOT)-still misfire.
Old 06-03-2010, 07:46 PM
  #41
gedis080's Avatar
Originally Posted by RKsilver
And Jess if i may say.. after all this time... problem couse was that ****ing continental or smthing (as i say CHEAP) timing belt, it had play on it, after change, everything runs just Great !
Verrry interesting end of the story !!! Is shock absorber with spring was proper adjusted ? , both rollers were in good shape ?
ContiTech (CONTINENTAL)belts are not 'cheap' product
http://www.contitech.de/pages/produk...estung_en.html
Might be that You had just wrong length timing belt ??
Old 06-04-2010, 01:51 AM
  #42
RKsilver's Avatar
Well, timing and tension was done in audi dealer.. and problem was found by nabour city shop, where they analysed everything, and they got to timing belt, 1600km driven timing belt was like 70 000 driven, as i say, camshafts were able to play even if the timing belt was on and tight.. it moved like 1.5mm to one end and 1.5 mm other end ..
Old 06-04-2010, 05:39 AM
  #43
V8QinNJ's Avatar
Fuel smell in cabin, in the trunk on the hump, remove the cover plate and verify that the sending unit and hoses are properly connected and tightend down.
Old 06-04-2010, 08:15 AM
  #44
RKsilver's Avatar
Just checked, nothing coming from there : /
Old 06-24-2010, 08:07 AM
  #45
RKsilver's Avatar
1 quick question about that transmission shift modes..
The switches are actually S E M
S stands for sport, which upshifts at higher rpms for maximum performance.
E stands for economy, which is for normal driving conditions
M is manual mode, for being able to shift through the 4 spds on your own using the shift lever.
So i want to know exacty how it works...
i have wners manual but its in german .. argh : /
i start slow, to 30km/h, i turn shifter to manual but its still orange...
when does it go green ?
does manual locks those gears ? like there is no slipping throw automatic gearbox ?
or how that exactly works ...
Old 06-24-2010, 08:20 AM
  #46
V8QinNJ's Avatar
From the 1990 V8 Owners Manual:
Old 06-24-2010, 08:37 AM
  #47
gedis080's Avatar
Page 43:
http://www.remontocentras.lt/Files/A...nstrukcija.pdf
You still don't have manual which You could understand ??? oh my GOD !!!
Here it is: http://www.remontocentras.lt/Files/Audi_V8_manual.pdf
Old 06-24-2010, 10:59 AM
  #48
RKsilver's Avatar
Gedis, i have repair manual...
i would like to find pdf as englist user manual as Scott put a picture of it..
Thnx
Old 06-27-2010, 08:27 AM
  #49
RKsilver's Avatar
Okei, now, as i have tried things i thought i should vag com it if i select that manual shifting
automatic gearbox ..
it gives me :
65535 - Internal Control Module Memory Error
08-10 - Control Limit Surpassed - Intermittent
baddaybeav
Q7 MK 1 Discussion
05-27-2019 06:21 PM
Audi0007
30v V6 Discussion
04-07-2008 07:29 AM
Alaska A6
Audi 100 / A6 (C4 Platform)
11-29-2007 09:03 PM
Realization
01-03-2007 09:26 AM
flojo0609
12-20-2003 04:43 PM
Quick Reply: After all of those months and spent money (ALOT)-still misfire.
