After-run pump
seemed to be quite noisy (first time that has happened) tonite... figure it is failing? Does 88 5000 tqm have after-run pump and will it fit my 91 10v? Thanks!
An A6 2.7TT pump is bolt in, more sturdy, repairable, AND less money new. Go figure . .<ul><li><a href="https://forums.audiworld.com/v8/msgs/140703.phtml">RussB's A6TT after-run pump post</a></li></ul>
I used to like having 2 of each model that I owned at a minimum. Tried to keep them both running. That way when one died the other was ready for action.... or to be a parts donor. You have a better idea if the part is good when the car runs!
was the blower motor for the injector cooler... which was running after the engine was shut down....so i thought it was afterrun. Troubleshooting to come I suppose. Is the blower supposed to run after motor is shut off?
