Anyone replace door/window seal?? On a 87' 5K CST
I'm in the process of replacing my window seal / door seal, you know the one that does all the way down the window tracks and has an felt covered edge.
I was able to remove some good looking ones from a newer 100 with the 5000 body style.
But I'm not sure about putting it on my car,
I'm sure that I have to take my door apart, but is there a TRICK to replacing it, use soap, tools ??
Has anybody BTDT ??
Thanks,
LarryF_in_Ca
Has anybody BTDT ??
Thanks,
LarryF_in_Ca
But if you choose to ignore that like the rest of us...
"Window slot molding, installing
- push plastic holding rail "5" (you need the image to figure that out so try looking at what you have) into place between door flange "1" and retaining clips.
- push window slot molding "2" onto plastic holding rail.
- install end cap.
- reinstall all mirror components in reverse order of removal. (Duh)
- check mirrors for proper operation.
Seems pretty straight forward. Any reason you can see for the warning about reusing the old trim?
- install end cap.
Patience is important for this job, to avoid tearing the trim. Just soak the tracks in which the molding resides with lots of silicone spray.
It's just a 6 inch long, 3/4 inch square, hunk of delrin (very tough, almost unbreakable, very expensive white colored plastic, sort of nylon-like) shaped like a long gently curved wedge. It's a 3/4 inch wide point on one end. I bought it locally for $16, which seemed expensive, but it has paid for itself.
I find that it's handy for pushing or prying breakable pieces such as interior trim, without scratching them or their surroundings.
gcheddar
11-21-2009 07:27 AM
Godfather | Jay
11-23-2007 07:54 PM
