auto trans fluid level dipstick question ( i know this sounds dumb)
1991 200 turbo automatic.
I only have the haynes manuyal and it doesnt explain the dipstick and there is no writing on it.
there are 2 holes and a VERY small crosshatched pattern and the very bottom. Is the crosshatch at the very bottom for cold fill with engine off or on? i'm assuming the 2 holes are the full range for hot and running. But i wasnt quite sure and its not labeled at all.
thanks,
Paul
thanks,
Paul
same trany stick used in my non turbo '87. The two holes represent high and low fluid marks. Check trany fluid level when engine and trany fluid are up to normal driving temperature. Check fluid level when motor is still running, trany in Park position. Add trany fluid using a funnel with a long drain stem. Your question wasn't dumb at all. I checked the owners manual, nothing written there about trany fluid maintenance.
TOMAS7
03-31-2008 05:26 PM
A6George
Audi 100 / A6 (C4 Platform)
03-13-2008 07:13 AM
bart7590
10-15-2005 11:36 AM
vert1go
01-22-2003 09:51 AM
summersr
02-28-2002 01:41 PM
