automatic tranny shifting
If a transmission won't shift out of 1st gear .. other then the fact that it is a bad transmission .. what other problems could i check? transmission speed sensor of some sort? tia
will this cause a problem?! i called a local Audi shop and they said it could be a governor problem. Looking at the tranny in the car .. can i take it out and clean it w/o dropping the transmission itself. Practice makes perfect but i'm getting tired of it.
do you mean the valve pump? i don't understand what you mean by this? I'm going to clean the governer in air intake cleaner just to be sure. other then that .. i'm stumped. I have parts avaliabe to swap out if it may be something else.
Normal morning start-up and this time I pulled foward out of my driveway. The car would not shift out of first for almost a mile. Not once has this problem happened since and the trans works fine with about 100,000 miles on it...
if the level drops, it will not shift correctly. BTDT on our old '87 5kS. Could not tell the trans was loosing fluid. I forget which seal it was (this was back in 1996 I think?)...
changes and torque converter lock-up. If my understanding is correct anyway.
how do it get to it. i'm planning on dropping the tranny to clean the governor for "fun" to make sure its not a question. Fluid is good. The valve body to my understanding is one the differntial part of the tranny? i'll pop it open to check her out.
Josh5442
04-15-2007 06:00 PM
86_5K
03-07-2004 07:24 AM
