Car runs only when timing is off a bit - any ideas?
I am finishing up a timing belt and turbo replacement on my 5000, and I'm having issues getting it to run properly. I noticed when taking off the old timing belt that the timing was off by three notches on the cam sprocket (if the timing belt moves in a clockward direction facing it from standing in front of the car, then the cam was behind - I'm not sure which way it spins). I set the timing correctly for the new belt, but it won't start. It starts fine only at the old position and one notch closer to the "correct" position.
I'm clueless why it would be this way. Any ideas?
Also, it's making a loud clicking noise (like sticking lifters) when it does run - which I'm concerned about.
check the distributor timing?
Someone may have changed the distributor position to make the car run as compensation for the timing belt being off.
When replacing a timing belt, make sure cam, crankshaft and distributor position are correct.
Distributor timing looks ok - any other ideas?
The rotor lines up perfectly with the mark on the housing at cylinder #1, when I have the timing correct, but it still won't start. It turns over, but just won't catch. Anyway, I don't think the distributer can be adjusted on this engine (MC).
Does anyone else have any ideas on why it won't start? Will it be ok if I run it with the timing off? Any help is greatly appreciated.
It will be OK to run with the timing off but
You really should try to figure out what is causing it to act that way.
Did you say it runs fine otherwise? If not check to see if any of the fuses along the side of the relay box are bad (engine related).
OGBULLYLOCDAWG
08-10-2011 08:18 AM
chris00tt
12
08-16-2006 04:58 PM
