Climate Contol Brain Replacement
I loaned out my Bentley's or I'd look this up.
How does one go about replacing the climate control controls? Do you simply pry off the trim piece and remove some screws or do you have to take the center console out?
Thanks!
Thanks!
you have to pry off the climate control wood trim. that snaps off. then you have two phillips screws on either side of the climate control that you unscrew. pull it out now and disconnect the back wires and its done!
I remember from posts a few years back that some part of the Climate Cntrol is the same as used by Oldsmobile. Does anyone remember what that is?
Many of the parts are from GM in general. Olds, Cadillac etc. It's a Delco part. The climate control head basically looks the same as in the early 80's Eldorados. (I actually owned a few of these)
Randolph
87 5KCSTQ
93 928GTS
Randolph
87 5KCSTQ
93 928GTS
<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=793809290 7&category=33545">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=793809290 7&category=33545</a</li></ul>
I'll bet that they're the only fasteners on the entire car that aren't metric.
