Clutch pedal ?
It's been about a month since the clutch rebuild. Everything has been fine until this morning. 12F outside, I pull my 200tqa out of the garage to take my son to school about 2 miles away, drop him off and wait at a stoplight for about 2 minutes with clutch in. Light turns green and I go, clutch only comes up about 2" but the car moves. I pull the pedal up with my foot and proceed, it does it a couple more times on my way to work, but only after the pedal was held down for a bit, works nicely if I'm quick with the clutch. Did it again tonight only 1 minute out of the garage.
I replaced the clutch slave and hose when I did the clutch rebuild. Had a tough time bleeding it initially, but everything has been fine until the cold weather hit. It acts like it did when I was trying to bleed it. Does this sound like a clutch MC going out?, need to rebleed?, moisture in the line?
BTW, I had to bleed clutch the unorthidox way, up through the bleeder to the resevoir to get it bled. Any thoughts??
Get a rebuild kit.
Pressure bleed the system. Number of threads in history on this.
MC under carpet by clutch. Looks like an easy job but sort of awkward to reach. You will need to grind down an allen wrench to remove one of the bolts.
JayP
10
02-17-2008 01:01 PM
audi/s/scott
12-27-2005 01:48 PM
s4bi4 X5
10
08-27-2001 03:36 PM
