coolant temp gauge is kaput
two days ago my coolant temp gauge starting acting up. it sits to the left of first mark of the gauge. barely comes up into the very second or third mark on the left of the gauge by the time the car should be running at reg operating temp. the gas mileage seemed to drop as well. initially one would suspect the t-stat but i just replaced that sucer within the last 10k miles with a wahler unit. can it be that the wiring or the actual temp sensor is bad and it is sending a wrong read out to the ecu causing a rich burn? thanks
Sound like the t-stat is your problem "the gas mileage seemed to drop as well". Even though the t-stat is new sometimes even new parts can break.
Get the engine up to temperature and see if both hoses to the radiator (inlet and outlet) are hot. Be careful when testing the hoses, they can be very very hot.
i will check the radiator hoses. is there a way to check the multifunc temp sensor before starting to thow parts at the car? i cant concentrate on the wagon fo the next two hours though, the World Cup is starting. i told my wife to forget about me for a month...
thanks for the suggestions
Can be the MFTS, can be a bad gauge. See Scott Mockry's wonderful resource and scroll to the section on gauge testing.<ul><li><a href="http://www.sjmautotechnik.com/trouble_shooting/cooling.html">http://www.sjmautotechnik.com/trouble_shooting/cooling.html</a</li></ul>
Kneale, Doesn't the multi switch run through the coolant guage? I would have to say that maybe one of the wires became corroded & broke off. Is the Black protective(yah protective) boot still intact?
But are you (skibuggy) getting full boost? I have Neds chip in my 200 & Ned told me to unplug it & see if the boost peakes cause it wasn't before. & wouldn't you know it I got full boost. So my next stop was the parts store for another Multfunction switch.
Thanx
Ron
90 80q 20vt AAN project
90 V8q 3.6 not stock
93 V8q 4.2 "The Green Monster"
& a Porsche 944 F.S
Thanx
Ron
& a Porsche 944 F.S
