Dash lights out + Occasional no start = Ignition Switch?
what I mean is that, if your ignition switch won't even work in the first position... no way will it start the car. That being said, I have never seen an ignition switch fail in all of the positions... just start position.
If your dash lights are out and the car will start - its not the switch its probably a loose connection/ground etc.
If the two are tied together, yes, suspect the switch.
Also - if you jiggle the key and it starts... also suspect the switch.
Only replace the switch with an OEM unit or else you will regret it. This is your one and only warning.
Refs
Audi 100 / A6 (C4 Platform)
08-07-2010 07:51 PM
JPCady
13
12-07-2005 05:37 AM
treehunter
10-15-2004 07:08 AM
EGainer
09-15-2004 09:28 AM
cortney miner
12-18-2003 05:30 PM
