distributor question...
im still tryin to get my 5k to crank itself over, and i decided to attack the hall sender this evening, as i got the trouble code 2113 for hall sender malfunction. in the process of breaking down my distributor i found a little spring about half in inch long just chillin at the bottom of the case. also, the hall sender seems to have about 35? of free rotation. is the spring supposed to hold back the hall sender anf stretch with timing advance? if so, where is its anchor point is and of the sensor is suposed to have that much free rotation? thanx in advance...
Eric
Eric
lots of them, theres an audi number whick looks more like a casting number, butin the same three number format as the o35 audi numbers, and theres a bosch number/casting number, not sure which is what. ill post the numbers later tonight when i get home.
Boosting1Bar
02-01-2002 09:36 AM
