Door apart, what to service
Had to open up my driver side door today 'cause the stupid little wire from the inside door handle to the latch broke....
so now that I have this thing open, any suggestions on maintanance I should do in there? I read about lubing the window tracks - I only see one in the middle of the door, is there more?
any other suggestions for preventative maintanace while I am in here?
You should see cables, you may find small openings where you can lube up the cables, also lube the tracks. Use oil or liquid wrench. Also make sure the open/close/lock mechanism looks good and perhaps oil up all of that too. Make sure the nylon snaps are in correctly.
PanzerWagon
12-03-2007 05:13 PM
Kingttr
12-05-2006 08:47 AM
