Emission testing
I've been having trouble passing the emission test (hydrocarbons) with my 91' 100. I've changed plugs, air filter, run injector cleaned through the gas, but not even close. Is there a way to adjust the air-fuel mixture??? Also, could a bad crankcase breather hose add to this problem???? Mine is soft and gummy.
Thanks
Thanks
if CO is normal and HC is high it is unburned fuel: probably a misfire. Cap, rotor, wires? I wouldn't adjust the A/F unless you can determine that is the problem for sure.
Then it probably is not the A/F mixture since the CO is low and the O2 sensor is only about 1 1/2 yrs. old. I'll try new cap and rotor.
Thanks,
Thanks,
make sure the car is warm to hot before they test it ... the catalytic converter needs to be hot to work corectly
I know you have done some of these, but I did a search on testing tricks.
>Oil Change
>Filter Change
>Hi-test (91+ octane) for at least a week--NON-Leaded (if they still sell the leaded beast in Canada).
>If it's fuel injected, get a product called Lucas Tune up in a Bottle. It's the best gas treatment around. That will help immensely.
>Emissions pass fluid, new O2 sensor, new plugs wires, coils, catalytic converter, all no dice.
>You may have a partially plugged exhaust passage that feeds the EGR valve
>Check the ignition timing. If it is too far advanced, it will raise the NOx. If the timing is okay, check the operation of the EGR valve. If it is okay, you may have to replace the catalytic converter.
> Check for a flat camshaft. If okay, perform a cylinder leak down test, which will pinpoint which valve is causing the problems. You may have to remove the cylinder head to correct this.
> If the engine that you have in your van has the 200,000 miles that you indicated, there is a good chance that the engine is worn out to the point that the blow-by will contaminate the exhaust, causing high hydrocarbon readings. We would recommend a motor overhaul to our customers in this situation.
>en<ul><li><a href="http://www.2carpros.com/topics/smog.htm">http://www.2carpros.com/topics/smog.htm</a</li></ul>
>Oil Change
>Filter Change
dassub
11
02-20-2009 07:57 AM
TonyMastodon4k
02-09-2009 08:25 AM
ga_mueller
06-22-2008 01:19 AM
