Engine running rough on a '91 100
It started with a 5 minutes when engine cold, then was ok. Later with more minutes and now it won't go from running rough. Checked the sp.plugs, distribuitor cap, air and fuel filter, fuel pump running ok. What should I do before going to a mechanic? Timing belt has 5000ml since new. Thank you guys.
check A/F ratio...
check the air to fuel ratio. if the intake sir temp is bad, it will most likely full field the fuel pump and send max fuel to the engine. will cause rich conditions and a bogging engine, increased fuel consumption and a strong odor of fuel out the tailpipe.
most accurate diagnosis is with a 5 gas tester, but try opening up the idle screw a little bit at a time and see if it smoothes out. if it does its over-fueling, and id chase after the intake air temp sensor. *make sure that you mark the original position of the screw. this will make it easier to reset everything once you repace the sensor or whatever is a fault*
good luck!!
good luck!!
golfindaily
11
02-10-2008 08:11 AM
dun
02-07-2005 06:19 PM
